Arducopter build from IDE
 Hello, dose anyone have information on configuring Arducopter to a traditional helicopter within the Ardino IDE. I have modified APM_Config file, setting FRAME_CONFIG  to HELI_FRAME. When the helicopter is powered up after uploading the code onto Ardupilot there is unusual servo movements. I believe the code has not correctly configured Ardupilot to a traditional helicopter.
Any information would be greatly appreciated.
  • What make model of helicopter and type of swash plate are you using, You need to use ccpm mixing.
         There's not too many details in your post so it's a bit hard to be sure what's wrong but below is what I stick into my APM_Config.h file.  By the way, you can find most of the active trad heli people on this thread.
    #define FRAME_CONFIG HELI_FRAME
    #define INSTANT_PWM ENABLED
    #define CONFIG_RELAY DISABLED
    // DEFAULT PIDS
    // roll
    #define STABILIZE_ROLL_P 0.70
    #define STABILIZE_ROLL_I 0.025
    #define STABILIZE_ROLL_D 0.04
    #define STABILIZE_ROLL_IMAX 7
    // pitch
    #define STABILIZE_PITCH_P 0.70
    #define STABILIZE_PITCH_I 0.025
    #define STABILIZE_PITCH_D 0.04
    #define STABILIZE_PITCH_IMAX 7
    // yaw stabilise
    #define STABILIZE_YAW_P  0.7
    #define STABILIZE_YAW_I  0.02
    #define STABILIZE_YAW_D  0.0
    // yaw rate  -- not used
    #define RATE_YAW_P  0.135
    #define RATE_YAW_I  0.0
    #define RATE_YAW_D  0.0
    // throttle - rate controller
    #define THROTTLE_P 0.22
    #define THROTTLE_I 0.1
    #define THROTTLE_IMAX 300 // throttle - altitude controller
    #define THR_HOLD_P 0.400
    #define THR_HOLD_I 0.020
    #define THR_HOLD_IMAX 300
    // navigation
    #define NAV_P  2.24
    #define NAV_I  0.03
    #define NAV_IMAX  10
