Hi. My EAST program is working on building an ArduCopter as our big project this year. We have the frame up, but now are starting to run into issues. I have all the battery connections hooked up well, the ESCs all connected properly, and the Futaba receiver wired up. Now, we come to the big problem. When we take it out to test fly, just trying to get a couple inches off the ground, the Arducopter flips. It did this on a table, in the hallway, and the grass.
My teacher and I did ESC calibration several times, and I've have attempted to level out the frame. I'm fairly certain that it is leveled out well, so I don't feel like this is a problem.
This brings up the big issue though, which is why the thing keeps flipping. Can anyone provide any help on this. Some detailed instructions maybe?
Also, we are using a 6 cell Venom battery (http://www.amazon.com/Venom-5000mAh-22-2-LiPO-Battery/dp/B0027GEYSE) and a Venom OPR2 Charger. Now, the battery is only showing 5 cells when hooked to the charger. I read that if you set it to 6 cells and start the charge it'll eventually bring the charge up enough for the charger to learn that this is the problem with the battery. Then stop the charge and restart it. When I monitor the charge of each cell, I see the charge of the cell reading 0.00 go up to 1.13 then 1.58, and then the charger errors out. Does anybody know of anything we can do for this?
Any help would be greatly appreciated. This late in the year our funds are a little low, so we'd like to get it in the air with the parts we have.
Several questions:
A picture of all this would go a long way to letting us help.
-=Doug
What version of APM are you using?
What build of Mission Planner are you using?
You don't actually get motor speed information but can get drive values to the ESCs.
Know how to pull a log file?
-=Doug
I tried the info mentioned at https://code.google.com/p/arducopter/wiki/AC2_Props_2 but the CLI>>>setup>>>motors command no longer works. I did run a few other tests while I was there, and some config stuff. Um I dont know how to read the motor speeds to make sure they are all running the same speed.
Try checking some of these possibilities...
-=Doug
also:
http://copter.ardupilot.com/wiki/troubleshooting-2/#ArduCopter_tilt...
Maybe above? It's easy to have props on upside down and rotations wrong. worth checking.
Sounds like battery is dead if you have that low voltage on one cell in the pack. The3DR power module is only good for 4 cell packs in case you using that.
Joe
