Arducopter frame alternative.
I plan to make frame with Trex 600 tailboom and 3mm plywood.
               A
B ---------Center--------- C
               D
I plan to use Turnigy 2217 860 kV with 12X3.8
One tailboom 21.5mm diameter / 625mm lenght. 70gr
Could you estimate A to center lenght ?  Any ratio ?
  • Hi this is my CoCo Frame,
    made from 5mm Birch Plywood and each side 2 Layers GFK.
    If someone need a 1:1 JPG sketch. Mail me please
    Mike
    Around 30cm would be ok. Most outdoor quad uses 60cm engine to engine distance due it has been proven to be best length. You can also check AeroQuad.com for nice building instructions with Trex booms.
