Can anyone tell me acceptable values for Gyro Roll when my craft is sitting on the table?
Can you explain the following Artificial Horizon?
http://tinypic.com/r/2edr3pt/7
I assume between this and my Turnigy motors that go "clunk clunk clunk" every once and a while its no wonder I dumped my craft on the ground today.
Should I be in plus mode or X mode? does it matter?
newb++
The artificial horizon should be pretty steady. Please tell us more about your setup so we can help.
--Did you go through entire Configurator setup process, including initializing the EEPROM?
--Did you calibrate your accelerometer offsets so they the sensors are showing zero?
--What version of the code are you using?
--Are you using a magnetometer and did you calibrate that?
