Hello all, I tired to fly the Arducopter Hexa jdrones 880Kv APM1 v2.6, in Stabilize mode at a lower height in no wind condition. Problem is it is moving in the backward direction while i am applying the throttle only
https://www.youtube.com/watch?v=hMQvY_BeJ2Y
I dont see this problem in the videos posted by others here. Shouldn't it just lift and drop at same location in the absence of wind?? What am i doing wrong?
    Most likely your frame is a little back heavy.
    No. Stabilize is not position hold. Did you set it in auto-trim mode and then hover for 15-20 seconds, then set it down and disarm? If not, read the wiki carefully about first flights.
