I'm waiting for my arducopter, in the mean time i would like to see the data it collects. Is there data from the flash posted somewhere? I mean logged flight data
Slide sw2(the white tab switch) to the rear to access the CLI function. Then open the serial monitor on arduino. To log, slide it back to the "1" position.
The optional telemetry allows you to send any flight data to a ground station. Transmitter channel values, motor, gyro, accelerometer, pitch, roll, yaw . . .
There are pre-programmed sections that can be transmitted with a command from the ground station.
You can alter the program to send any data that is of interest to you.
Serial Commands
SENSOR:1655,1660,1671,2044,2034,2496,1540
ATT:5,-7,0
SENSOR:1655,1660,1671,2044,2034,2496,1539
ATT:5,-7,0
RADIO:1496,1500,1100,1511,320,2
SENSOR:1655,1660,1671,2044,2034,2497,1540
ATT:5,-7,0
SENSOR:1655,1660,1671,2044,2034,2499,1539
ATT:5,-7,0
RADIO:1496,1499,1100,1511,320,2
