Arducopter log data
Hi
I'm waiting for my arducopter, in the mean time i would like to see the data it collects. Is there data from the flash posted somewhere? I mean logged flight data
  • Slide sw2(the white tab switch) to the rear to access the CLI function. Then open the serial monitor on arduino. To log, slide it back to the "1" position.
  • The optional telemetry allows you to send any flight data to a ground station. Transmitter channel values, motor, gyro, accelerometer, pitch, roll, yaw . . .
    There are pre-programmed sections that can be transmitted with a command from the ground station.
    You can alter the program to send any data that is of interest to you.
    Serial Commands
  • it looks like this:
    SENSOR:1655,1660,1671,2044,2034,2496,1540
    ATT:5,-7,0
    SENSOR:1655,1660,1671,2044,2034,2496,1539
    ATT:5,-7,0
    RADIO:1496,1500,1100,1511,320,2
    SENSOR:1655,1660,1671,2044,2034,2497,1540
    ATT:5,-7,0
    SENSOR:1655,1660,1671,2044,2034,2499,1539
    ATT:5,-7,0
    RADIO:1496,1499,1100,1511,320,2
