Arducopter Starting Problem
Hello.
I am using arducopter 2.055 FW uploaded by Arduplanner.
After I finished the settings and connected everything, the APM had no response to my control and LED A and C just kep blinking. I cannot arm or disarm the motor.
Have anyone meet this kind of problem before?
    It sounds that you ended up on configuration mode or your gyros are not properly initialize them selfs. Make sure that your throttle is on minimum when you start your AC hardware otherwise you will end to throttle calibration mode.
    there are several LED modes on current AC software, would be good it you could post a small video clip on how your leds are blinking. Would tell a lot more.
  • do you have the servo travel on the rudder channel at 100%? if not re do the tx settings so the system knows where full left and right are !
