Arduimu
I flew Arduimu today with Ardupilot and Ardushield V2. Since I don't have any GPS module available, I only flew the autopilot in STABILIZE mode. In MANUAL mode everything is trimmed and the plane flies OK.
However, in STABILIZE mode the plane banks couple of degrees to the left (as seen from behind). I mention that I did the entire initialization of the Autopilot/Arduimu on a flat surface according to the manual. Is there an option in the code to fix this non-trim behavior?
One more thing:
During the flight, in STABILIZE mode when I noticed that the plane banks couple of degrees to the left I trimmed it a little bit to the right and everything was OK. However when I switched back to MANUAL mode, the plane would now bank to the right, which is logical since as I said, I started with the plane trimmed very well for the MANUAL mode. The plane basically goes out of trim once I switch to STABILIZE mode. It doesn't go too much out of trim... just couple of degrees of bank to the left...
Best regards!
  • Can you run the ground test station for the ArduIMU with out the gps? I read in the site that it says you can but your yaw data will be off.Does any one know why the test station is not picking up my imu? In the arduino I can see my data in the serial port but cannot get it to run in the ground test station.Labview
  • Um, what Chris said, with a little clarification.
    The yaw gyro will drift. With no correction, the AP will think it is turning a little. For example, 1 degree per second right. So the AP will command a turn of 1 degree per second left.
    Yes, ArduIMU (like any IMU) will not hold a bank without some sort of yaw correction (magnetometer or GPS). You must use it with a GPS module; it will not work reliably otherwise.
Saturday
