Hi.
I flashed APM with ArduPlane 2.28 From APM Planner 1.1.34 , and executed "setup" and "reset" in terminal.
At first I noticed that inverting roll axis was impossible after the initial calibration, I inverted roll axis by modifying "-1" on CH1 to "1" -   The GUI does not reflect this on the calibration screen.
That's not the worst part;
Manual mode gives (naturally) smooth aileron operation
Stabilized mode, - compensates correctly for APM roll. - smooth and nice.
However: in stabilised mode, I can move the stick to one way, and roll nicely, but at the end of the other way, the aileron goes absolutely bananas, jumping around randomly, while I hold the stick steady.
Is this firmware stable ? - what do you fly ?
  • - This happens only when throttle is all the way down !
    *IN* CH1 jumps randomly if at low value when throttle is down.
  • Yes, completed radio setup (multiple times) - and min,max, and center values seem fine.
    only reversing does not seem to stick, at all, unless done manually.
    found no reason to the shaking.
    please see this video - it shows it very well (observe display for mode/AHI):  http://youtu.be/0NVJV3AlLQw
    as for your problem. did you do radio setup properly?
    looks like you found a bug. if you switch tabs in that screen and back again it fixes itself.
