Ok. This is real strange. I finally got it working. But here is the catch. I have to plug my APM board into the pc. wait a few seconds, then plug in the battery and then I get tones from the ESC's. I unplug the cable from the pc and it work. Any comments would be helpful.
ok. I've tried that too. When I have the APM board hooked up to the pc and run throught everything. Then I start getting continous beeps from the esc. Not sure why that is happening either. But when I unhook the battery and hook it back up nothing happens.
Yes. I followed everything as it stated. I plug the battery in and no sounds coming form the esc. I get the light on the board and can arm the board, but still no motor response. I can get the motors working if I hook them staight into the receiver, but nothing when I hook it into the ardupilot. I don't understand the phrase PDB.
Ok. I got the board working I think i had a couple wires crossed. But now here is the big problem. I have calibrated each esc (Turnigy Trust 45A), but when I hook them all in together to the Full Ardupilot Mega Kit, I soldered up and have previously tested. The ESC's dont' do anything. I can't understand it.
There's not enough information here for people to help you. Which board? How did you plug in your battery? Are you using the standard PDB? Did you do the soldering yourself and if so have you checked it for shorts? Maybe include a photo of your connections, too.
I tried some different motors and esc's and they work fine. But these Turnigy Trust don't beep unless I hook up the usb first then the battery.
I am not sure how to do all of them at the same time.
