ArduPilot won't boot from battery power
I just completed building a quad-copter, and I got everything configured and working using the Configurator CLI.  However, once I disconnect the USB cable and try to boot from only the battery power coming from one of the ESCs it simply does not boot.
I have the power connected exactly as recommended in the Wiki page:
         3 ESC voltage lines are cut, and 1 ESC voltage line is used to power the APM.
I am using the recommended ESCs (Turnigy Basic 25 A), so I do not think its an issue of cheap ESCs not supplying enough power.  I checked all voltage lines on the APM using my DMM, and it all reads  the correct 5V.
After searching some Arduino forums, I found that in order to boot from an external battery sometimes you need to tie the FTDI Rx and Tx together or pull the Rx pin to ground using a 10 K resistor.  This is because the Rx pin reads in garbage without the USB connected so the bootloader never times out and doesn't get kicked off.  So I tried to tie the Tx and Rx together and use a 10 K Ohm resistor to pull the Rx to ground.  Neither method worked.
I was finally able to get the APM to boot after pulling the Rx pin directly to ground (no resistor used).  It appeared to boot properly, but I was unable to control the motors via my RC transmitter.  (I am able to control the motors fine with my RC transmitter with the USB plugged in.)
Any thoughts,
Gene
  • I am doubtfull that trying the other ESCs will have an effect, but I will certainly try it later today.  I will also try to de-solder the SJ1 jumper and connect power directly from the battery (11.1V 3 cell).
    Could this possibly be a bootloader issue since the APM boots once I pull the FTDI Rx pin to ground?
    Check the SJ1 solder jumper. If it's not present, the board is expecting a seperate power source (the boards are shipped with that bridged, but maybe yours doesn't have it? It's easy to add if so)
