I'm working on testing the electronics for my first ArduPilotMega build. When I enter the Arduino Serial Monitor test mode 'test', 'radio' and move my transmitter sticks, I see the input values changing for 4 of the receiver channels (so far so good). However, the 'OUT' value changes only for 3 of the values (out 1, 2, 4). OUT 3 never changes.
Since I can see the input values changing, it seems like the transmitter, receiver, and jumper are all setup correctly. Could this be a software configuration?
Thanks,
Peter
failsafe problem on the throttle - pls. tun off this feature.
do you have a 'compatible' receiver for which system?
