Posted by Ahmed Rehan on October 12, 2014 at 2:24am
ArduPlane 3.1.1 not working proper on flying wing any body else facing problem as soon as switch on to fbwb or auto mode it nose dive and roll on one side.
Looking at your log it is clear your RC calibration is a long way off. When you are flying in manual the zero of your sticks is around 1600 for channel 2 and 1447 for channel 1. Those values need to be in RC2_TRIM and RC1_TRIM so that ardupilot knows when you want the plane to fly level. It also looks like your _MIN and _MAX values are wrong. So start by re-doing your RC calibration. I suspect you may have skipped that step. You may also like to read up on the TRIM_AUTO option (make sure you read the docs carefully to understand how it works).
You should also fly in FBWA or AUTOTUNE before any other mode. Your flight log shows most of the flight is manual, then you skip straight to auto. You do spend a couple of seconds in RTL and FBWB, but not enough to actually tell how it flies.
I'd also highly recommend you read up on AUTOTUNE mode. If you are already comfortable flying the plane in manual then try AUTOTUNE_LEVEL=7.
Cheers, Tridge
Ahmed Rehan > Andrew TridgellOctober 13, 2014 at 11:38am
I think you are right trim seems to bit out i will enable auto trim and will test the result also will recalibrate the radio.
Ahmed Rehan > Andrew TridgellOctober 13, 2014 at 5:21am
Usually a setup problem, many are using AP3.1.1 quite happily on a flying wing. Test on the ground with the aircraft level, If you switch to FBW_A (don't use FBW_B just yet) then the elevons should stay level and move in their correct directions when the aircraft is rolled or pitched. If not your setup is wrong.
Ahmed Rehan > Graham DyerOctober 13, 2014 at 12:03am
It is not a problem for configuration what I think it is not taking the altitude it seems it is trying to go to altitude below 200M were as I have kept the default altitude 200M and I also tried to give higher altitude but same behaviour what I assume the Eprom is not flashing write value and in one flight it worked ok also.
Ahmed Rehan > Graham DyerOctober 12, 2014 at 3:02am
I have checked the elevon on ground direction is ok also tested in FBW_A same issue could it be a hardware problem? on flying wing i am not using rudder channel from radio do i have to close yaw gains?
I have checked both TX and APM moving it in pitch and roll.
Steve Cain > Ahmed RehanOctober 12, 2014 at 2:06pm
I regularly fly 3.1.1 on my flying wings... it works nicely.
The failure you describe could be related to a couple of things in your setup.
1) the level for the APM has to be calibrated (set it with a few degrees of up (positive incidence) and wings level) without a little positive incidence in its level reference the wing will descend when in FBWA.
2) The problem you describe sounds like the APM is configured incorrectly. The APM has to move the control surfaces in the correct direction in FBWA... Not just move the right way the Radio input to test this, without any input from the xmtr roll the wing left and right... the aileron on the high wing should come up. with the nose pitched down both ailerons should come up. If it does anything else, you have a config issue.
Hi Tridge
attach pl find the log of successful flight.
Ahmed
2014-10-02 13-36-48.tlog
Attached find log file
2014-10-11 15-43-32.tlog
Hi Ahmed,
Cheers, Tridge
I will re calibrate and will check the result
Best of luck
1
2
3
of 3 Next
