  • Are you using the Airspeed sensor. If yes, and it is "enabled" make sure it is reading airspeed, had this issue with my FX-79, found my airspeed sensor was not reading, and was enabled, and in every Auto mode, it thought it was stalling, so it dove to gain airspeed. Also, I just had a crash this saturday that involved "min airspeed" beign set FAR too low, my fault I know, but this created a situation where the airspeed was a bit too low, and turning from down wind to an up wind situation, the aircraft tip stalled into a irrcoverable spin dive. Out of curiousity, which airframe are you flying?
    • Jeff what is your RTL altitude?
    • I am not using airspeed sensor and it is disabled min air speed is well above stall speed. Airframe is custom cnc cut 3 part flying wing 2M span will post photos later.
      • Its 99.99% likely that Tridges recommendations will solve your problem.
        I recently bought pixhawk and the last firmware version I used until recently was 2.67, since then a new method of elevon mixing had been introduced, which had me stumped for a day until I found this page
        http://plane.ardupilot.com/wiki/arduplane-setup/first-time-apm-setu...
        Make sure to read it carefully in particular the chapter - New style elevon mixing EEPROM setup (ELEVON_OUTPUT option)
        • yes i already checked this and tested using elevon_output option in manual mode it is ok. i will do next flight after recalibration and will update.
          • Thanks to every body specially Tridge / Gary
            Just Tested with new calibration worked perfect tuned with auto tune.  tested FBW_A and auto mode also worked perfect. The P gains were too low as default . will test auto takeoff and land and will update.
            Ahmed
            • Today Auto takeoff worked perfect will try auto landing in next flight any suggestions on approach of autolanding height and distances.
              • I also am having this problem that you have now corrected. I am flying a Hercules wing on 4S, twin engine. The last two flights when I enabled RTL my plane ended up in a steep dive, both times I regained control. I am using the new digital airspeed sensor. My main question is, if I was flying at less then my cruise airspeed of 17 m/s when I engaged RTL, would the plane drop altitude to gain speed. Thanks for your help JEFF
        Ahmed, Tridge has responded, it is a setup problem please undertake the steps he has advised.
        • Gary /  Tridge one thing i cant understand it flew one mission with the same setting ok navigating all waypoints and then started orbiting over head.
DIY Robocars via Twitter
Jul 4
Jul 4
Jun 25
Jun 25
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
