Artificial Horizon in Configurator
I have a standard setup ArduQuad which I have flown only a few times. I have had motor control problems on most flights where it has wandered off on it's own mission - no great damage. This is normally after minutes of quite stable flight (all soldered joints - no connectors)
The problem I have now is after using CLI and configuring everything including magnetometer, when I use configurator, the Artificial Horizon does nothing.
The mag etc. seems OK in CLI and seems to calibrate OK and does end up with North as North.
In the 'sensor indicator' mode of configurator all seems OK if you tilt and turn the quad.
Has anyone had a similar problem where calibration goes OK and in the Artifiacal Horizon mode nothing happens?
Any ideas would be greatly appreciated.
  • i have the same bug here, just reconnect
    it doesn't work sometimes...
