Wiki Ninja
AttoPilot voltage & current sesnor calibration
I soldered a 180amp AttoPilot v & c sensor; measured the input voltage to APM 2.5 (10v); input 10v into the MP > configuration screen. I also entered 5000 for the 5000mah 3S LIPO.
The result I'm getting is around 25v. It should be arround 12v..
Is there something else I need to do?
  • Any update on your issue? There is no way you're going to fly with 10v powering the APM - it would burn up..
    If you have set up your power system in the typical fashion, you should have a connector coming from your power dist. board that is a back-feed coming from one of your ESC's that give ~5 volts to power your APM.. You subtract 0.3 volts and enter the new value in the MP sensor screen (at 5.0 volts, enter 4.7 in MP) - That should get you just about there..
    Some people need to adjust the volt/amp ratio in the param screens to tweak the readings.. Not entirely sure why it isn't automatic, but 'tis life...
  • The value you enter should be around 5V, not 10V. Measure between the + and - on the row of sensor input connectors and subtract 0.3V. This is the value you enter.
  • Wiki Ninja
    Bump
