I've got an APM 2.5 with the latest x8 firmware.
I'm using a ppm receiver. I'd like to control a servo from one of the auxiliary output with a PWM signal.
Is it possible to do this (map one of the ppm inputs to a pwm output on the apm?)
Antoine
I noticed this post doesn't receive any answers yet. But how are you doing right now? Do you got the problem fixed? I currently having difficulties to understanding the working principle of the Auxiliary Servo Outputs. Can you share a bit with me on how to use it? Cause I have lots of things I want my UAV to do and auxiliary servo output maybe the answer but I can't make it done. Thank you in advance
I use the gimbal setup functions to do this sort of thing and turn off the "stabilization" feature which makes them go straight through.
