i'm not sure exactly where to post this but I hope someone can help me. I purchased the APM 2.6 Mega with Ublox GPS (with compass), minum osd, 3dr power module, and telemetry from Readytoflyquads.com.
I have setup the board and run Mission Planner wizard with no problems. I calibrated and leveled my accelerometers and Mission Planner showed the artificial horizon as level as long as I don't move the board. When I do move the board the horizon on the computer responds correctly to my movements but when I place it back on the table the horizon continues to move as far as 60 degrees back and forth until I unplug the board. I also occasionally get a "bad gyro health" error.
I have uploaded a video to Youtube which can be found here: https://www.youtube.com/watch?v=QxJBEwjVpVo
If someone could please look at it and see if I am doing something wrong I would really appreciate it.
Thanks in advance.
Jamie
In Mission Planner, go to the Initial Setup tab. Click Install Firmware. Bottom right is a "previous versions" option.
I've attached an image of what you should see.
1.2.97 but I can't imagine an update would remove that feature. I'll keep looking at it. Perhaps there's an option to display that menu somewhere.
I installed 1.3.4 today. The option to install older firmware is not there. I'm getting the Bad Gyro Health message; I checked the I2C port voltage, its giving out 4.4V. I have an APM 2.5 from jDrones. I've had it for over a year now, just got it setup now. Had been using the APM 2 before this. I wanted to know what gets affected if you've got a blown regulator. Is there any way the board is still usable?
Alright, I went into Config/Tuning and checked Advanced View. That brought those options back. Hope this helps :)
Hey, I had the same problem. What fixed it for me was rolling back to an earlier version of ArduPlane. I think 2.76.
Thank you! That fixed my Bad Gyro problem as well
