Hi everyone. I'm new to multirotors and have a question regarding batteries. I've built the 3DR Arducopter kit with APM 2.5. I've been using 3 cell, 11.1v 2200mAh lipo batteries. I am able to get 9-11 minutes of flight time per battery. I'd love to be able to get more flight time.
I've read several sites about batteries and understand them this way - lipos have 3.7 volts per cell, thus a 3 cell has 11.1 volts. Capacity is measured in mAh. The higher the number the higher the capacity.
So here's my question - as long as I stay with a 3 cell 11.1 volt battery, can I upgrade the mAh number? I saw some 5000+mAh batteries that were 11.1 volts and assumed that one of these would give a longer flight time. True?
Also, I've come across some cables that let you run 2 batteries in parallel. Obviously this adds more weight, but is this another good option for increasing flight time?
Thanks.
But once you 6S, you never go back 4S...:-)
(Caveat: I run 3S and 6S. Logic would dictate a 9S or even 12S monster next...:-)
Thanks for the replies. I just didn't want to overpower and burn something up. Since my post, I've looked at what I have plugged in on my Arducopter - The APM Power Module says it has an 18V max input. I'm assuming that the little circuit board on the Power Module is what regulates the power going to the APM 2.5, so as long as I stay under 18V I'm good. The ESCs in my kit specify "2-4 LiPO, 5-12 NIHM/NiCd" in the battery section.
Starting to understand this stuff more and more each day, thanks to this forum!
Good luck and fly safe.
