    I've got a 3S 1800 mAh lipo in mine, and it works well.
    - snipped the connector from the supplied battery pack
    - soldered a JST connector to this lead.  double check your polarity
    - attach the battery via the JST connector
    I had the junky 3S sitting around.  It came with my Hawk Sky, but I use Zippy 2200s with that plane.  Luckily, it is the perfect size for the battery compartment.
    Voltage drop is less than 0.1V/hour.  I'm careful not to let the battery go under 9V, but that hasn't been a problem so far.
    On the downside, you don't get a beeping warning for low battery, but so far it hasn't been necessary.  I'm not able to detect any heat buildup from the linear voltage regulators.  If I would have had a spare 2S battery I would have used that one, but as I said I had a perfectly size 3S just going to waste.
  • Could this fit?
    http://www.wowhobbies.com/transmitterbattery-lipo2200mah15cbatteryf...
    Web Page Under Construction
    Network Solutions - Original domain name registration and reservation services with variety of internet-related business offerings. Quick, dependable…
  • Look at this form:
    http://diydrones.com/profiles/blogs/turnigy-9x-9ch-transmitter
    There is a whole discussion on battery options and mods.
  • Thanks @tonyH, @cronselaar and @Simon for the information and specially for the link to rcmodelreviews. Great stuff there!
  • I'm using a HK Zippy 800mAh 2S Lipo - fits just fine.
    You either need to make the change to the two resistors (RCModelreviews ref as before) or, better still, re-flash the software with the er9x code and just change the alarm point.
    This is a great and cheap Tx but with loads of DIY mod options to be found on the web- changing the battery is just the first step.
  • Hi
    I have a 9X and would not suggest that you use the battery you have linked. All the internals work on 5V so giving it the 12V is a total waste and would only be turned to heat. See: http://www.rcmodelreviews.com/tendollarbattery.shtml
    I used all the instructions on the resistor part except that i'm using a normal 2cell from HK. It does require soldering and cutting off the plug on the old 8xAA battery holder but works really nice.... Using my TX for 1 to 2 months before it needs a recharge. If you need the inside dimensions of the battery bay to get the right battery i'll happily measure mine.
    Kind regards
    Gerrit
    A 2400mAH Lithium Transmitter Battery For Just $10
    Fit a 2400mAH battery to your 2.4GHz transmitter for $10
  • I'm not sure if anyone has done it, but some rewiring would have to be done to use a LiPo with the Turnigy 9x. Normally, it uses 8x AA batteries.
