Battery Voltage measurements wrong
I setup my APM2.0 to measure the battery voltage and is seems to be not working correctly.
I filled in the fields with the battery voltage and the APM input voltage correctly but the calculated voltage is giving random results from as little at 3 volts to as high as 35 volts.
I measured the voltage at the APM and the battery and they are stable.
I am running firmware version 2.7.3 in my Quadcopter.
I am wondering if it is a bug or do I have a hardware problem.
  • What Voltage /Current sensor are you using? You are using one, right?
