Beginner help
Hi All,
First of all thank you for your support to this new beginner... I´m a bit lost and after reading thousand of documentation I come to this Forum for help.
I got a Aducopter firmware version 3.1.2
I can not down load new version, but it is not a mayor problem today.
I connect the planner and I can calibrate the radio and see in the "fly data screen" that APM is working.
But I can not arm it wiht the radio, so I can not progress to fly. I also deactivate deh parameter "pre-arm-check" but no success.
I check all voltages in the receiver and APM an are correct.
I can on ly see a red led bliking.
Any idea?
thanks
  • What version of the APM?
    Do you have a GPS and compass connected?
    Hook up to mission planner (outside, where the GPS can get a fix) and try to arm. It should show an error if you try to arm if there is a problem.
    • Hi
      this are some data:
      APM Consejo regulador de vuelo APM2.6 para Multicopter de ArduPilot MEGA 2.6, no compas nor GPS conected
      firmware version arducopter 3.1.2 (I can not upload newest version neither)
      I tried to run the wizard, but the acceleometer test fails, but in fligh data windows I can see the ground line moving when I move the tricopter.
  • Did you go through the entire setup wizard?
