HI,
I am new member in the X-UAV Talon club, I have just received my Talon with the extension wing.
I'm working to put the right combination of motors, prop and batteries:
I am looking to have the maximum flight duration over 90 minutes.
The weight of my FPV gear with all antennas, cables, cameras is around 750g.
The weight of the talon + motors + ESC + servo is around 1400g, So the total weight without the batteries is around 2150g
Regarding the battery, I can use multiple options based on motors and prop:
Multistar Battery Weights:
3S 5200 mAh is 325g.
4S 5200 mAh is  433g.
Option1: 3S configuration 2 parallel batteries => 3S 10,400 mAh: 650g. Total flight weight 2,800g
Option 2: 6S configuration, 2 series batteries => 6S 5,200 mAh: 650g, Total flight weight 2,800g
Option 3: 4S configuration, 2 parallel battery => 4S 10,400 mAh: 866g.Total Flight weight: 3,016 g
Option 4:  3S configuration 4 parallel batteries => 3S 20,800 mAh: 1300g. Total flight weight 3,450g
Option 5:  6S configuration 2 parallel + 2 series  => 6S 10,400 mAh: 1300g.Total flight weight 3,450g.
What motors and prop should we use with every option, and what flight duration will we get?
I have those motors: but I can buy others if needed:
Motor 1: OSMG9530  http://www.osengines.com/motors/motors/motor-specifications.pdf
OMA-3825-750
 (.30 Size)
Rotor Diameter (mm): 38
Magnet Length (mm): 25
kV: 750
Watts: 590
Weight (oz/g): 6.7 (190)
Motor 2: Jamara E-Motor Magnum A2820/6
http://www.conrad.at/ce/de/product/428816/Jamara-E-Motor-Magnum-A28...
Specifications  Revolutions / v : 1000
Internal resistance : 59mOhm
Idle current: 2.0A
Max A: 37A / 60S
Shaft Diameter : 4.00mm
Output: 550-Watts
NiMH Battery : 8 ~ 14
LiPo Battery : 3 ~ 5
Propeller NiMH: 11x8 Propeller LiPo : 3xLiPo 11x6 / 10x7 4xLiPo
Application: 1000-2500g
Motor 3: Emax BL2826/06: http://www.toysonics.com/emax-bl2826-06-950rpm-v-outrunner-brushles...
Features
  • New Emax BL2826/06 950Rpm/V Outrunner Brushless Motor
  • Model: BL2826/06
  • No. Of cells: 3-4 Li-Poly
  • RPM/V: 950
  • Max. efficiency: 86%
  • Max. efficiency current: 20- 30 A (>78%)
  • No load current / 10V: 2.1 A
  • Current capacity 61 A/60s
  • Dimensions: 30x26 mm
  • Shaft diameter: 5 mm
  • Weight: 182 g/6.41 oz
  • Recommended model weight: 2-3.2 kg
  • Recommended prop without gearbox: 13*8; 12*8
Elios
    • A 40 A ESC "should" be fine, you won't be drawing that much current.
      Don't use wooden props, the tips will hit grass/twigs, etc on landing, and break.
      • I have been developing multicopters so no deep knowledge for planes.
        I got the idea against wooden props.
        Actually, I think the same danger (hitting the grass/twigs) exists for APC props.
        I have never used wooden but will try.
        @Eliot,the negativity is price.
        ZTW 40A opto 600hz esc $14 while 90A opto YEP esc $111.
        Anyway any esc opinion for sunnysky 3508 580kv?
        • Baris, my current measurements are somewhere on this blog....
          APC props get marks on the from hitting grass, etc, but they don't break easily.
          Electric wooden props are very flimsy.......
          For landing I cut all power, and let the motor windmill, it sort of acts as an airbrake.
          Also, if it is spinning on landing, it won't hook up easily.
          My feeling is that a stationary prop can hook up solidly with vegetation, and rip the motor out, or break. I've seen that happenon someone else's aircraft...
      • I am using 3S and I see 37A + when I am at maximum speed. that's why I prefer 75A and already I had the 100A so I am ok with it.
        I don't know if there is some negativity in it. is there?
    • Go for the Castle Edge. http://www.castlecreations.com/products/phoenix-edge.html  75 or 100
      or http://www.castlecreations.com/products/phoenix-edge-lite.html   75 lite or 100 lite.
      They are the best.
  • I've tied the config on 17" with e-calcs and i got this with RcTimer X6 motors (X6 Motors):
    3701962213?profile=original
    If i try on 13" i loose flight time
    X6/400KV & HV40A 4 pack combo
    RCTimer - the world's No1 Online Hobby Store. We stock a huge selection of RC products from Planes right through to Quadcopters and all accessories.…
    • Hello everyone, I have the full size XUAV talon, I have a turnigy 70amp dlux ESC and a 3548 1050kv turnigy aero drive SK3 motor. My talon has had the 1080 kv type motor on it before but due to teething problems I crashed it and have since done some repairs to the air frame using anew nose and some fibreglass. It is balanced but the weight has increased by around 800g, using 6000mah 4s lipo what type of prop is recommended to succeed in hand launching?
    • 100KM
      Joffrey, are you talking about a quadcopter?  Perhaps I'm the one confused, but I believe Elios posted about power systems for this:
      • Oh yes i'm talking quadcopter, i don't understand because my frame's name is "Talon" too
          @Joffrey, I don't know who the manufacturer of your quad is, but the Talon fixed wing (as pictured above by  Trung Nguyen)  has been well-known with-in the community for a couple years now.
          Sorry the quad company didn't pick a new name for their craft.
