  • Admin
    @Steve,
    You might try here: IRIS Documentation
    TCIII Admin
    • Thomas,
      I just completed my first 3D Robotics Iris flight, and while in Altitude Hold Mode the copter was drifting forward while the right stick was in the center. I constantly had to pull the right stick back in order to keep it at a close distance.
      Is there a setting or calibration that I missed during setup?
      • It happened the same to me. Probably it was a bad calibration of the accelerometers. Probably when you started the drone and you pushed the red button to make it fixed RED you were not on a flat surface.
        I am just wondering because this is happened also to me on the first flight and I was a bit inclined in the direction in which the quadrotor was drifting. Then I went on a flat surface with the same quad and it worked perfectly.
        Hope this helps,
        Fab.
    • That helps! Thank you!
