I have been reading on several threads and the installation instructions, and mounted my setup on Dynaflite Daydream, but had a few questions :I mounted the ArduPilotMega using 3 wood screws. Used Futaba's rubber grommets and brass eyelets to reduce vibration issues. However not sure if it would be better to mount with just the double sided tape ?In that case, I am concerned on directly using the tape on the circuit board.Should i use a wide heatshrink tube to enclose the entire APM and then stick using the Double sided tape ?Thanks !GA
