Hello,
I have read in many places on the site that the Arducopter battery must be switched off or disconnected before connecting to the USB, or irreversible damage may occur. Is this still going to be true on the production release and with your own power distribution board? My feeling is that however disciplined one is, sooner or later it's gonna happen that both get connected together.
If so, couldn't this feature be designed out?
regards
    I've heard this as well and so I try not to connect the USB and battery at the same time but as you say, invariably I forget sometimes and then notice, "oh shoot, they're both connected!!" and frantically remove one or the other. But in any case, I haven't blown anything up.
  • I blew my MUX chip by having the ESCs and USB connected without the battery, so I just replaced it (I have the tools). Having the battery and USB connected together should be fine as long as you don't disconnect your battery or turn off your computer.
    Yes even I connect rather often both USB and battery on same time and only time when I blew by FTDI chip + MUX chip was the time when I accidentally misplaced my ESC connector one pin too up.
    Power distro board helps a bit on this due you do not put ESC cables directly to APM inputs and you have separate power cable coming from power pcb to APM.
    We are just waiting our new power pcb's to arrive from factory.
    I do that all the time and have never had a problem. I think the only way you can blow up your board is to plug in a RC connector wrong (offset by one pin) so it put voltage on the signal line, or plugging a battery in without an ESC/BEC or some other voltage regulator inbetween.
