blown telemenery port (uart)? on 2.5 board
Hi All
         I think my telemetry port may be damaged.
I tried to set up a minim osd but i failed to understand the wiring correctly.
this worked ok when powered from the usb link
however when i connected the main lipo battery   (camera and Tx 12v  from balance plug)
I got no video pass thro or osd  opps!!
next I connected 3dr radio link Thinking this would be better than osd,
However i get no response from the port.
I have a second amp 2.5 board and the radio link works perfectly on that.
my question is this can i use a spare uart  to connect to the radio/osd  telemetry port
I notice that there are solder jumpers to change uart connections??
do i have to change software settings to do this??
Thanks Tim Painter
  • no where an expert, and haven't tried this myself for this specific purpose (did it to have 2 telemetry out ports both were working):
    there are at least 2 serial ports on apm 2.5+  to access the second one open the case, solder 4 pins on the apm board (the pin holes are marked gnd, tx, rx, vcc). there are plenty of tutorials on how to enable the second UART port on apm 2.5.  In the even you damaged your UART0  there is a chance that your UART1 is alive.  (Vcc is just 5 volts, do not connect 12v from minim to it and do not reverse your polarity)
