Boot Problem?
Hi all,
today I've loaded the new 2.26 version.
The first flight is OK, but when I 've tried to restart the APM it won't boot.
I've tried to connect to it by USB port and moving the switch I've done a reset by the CLI.
The reset was ok, but nothing to do, It won't boot (no A B C litghs).
I've tried to load the last arducopter firmware, and with this firmware the APM boot fine everytimes. (A B C calibration, and Mission Planner connection)
So, I've tried to reload the 2.26 by the Planner and by Arduino 0022, nothing to do. APM don't boot.
using the CLI I've seen that it stop booting after writing:
Init ArduPlane V2.26
Free RAM: 2016
load_all took 8368us
using 2932 bytes
Any Idea?
TNX a lot, by.
 (19 resets)
    I'm guessing that you're not using the magnetometer. ArduPlane 2.25 and up seems not to want to boot without a magnetometer attached (we'll fix that this week). In the meantime, use Arduino to load 2.24 which should work fine.
