Hi guys
Bought an X8 RTF in the weekend sale. While I'm waiting for the X8 to arrive, I'd like to plan ahead a bit.
There are very few tech specs for the 3DR X8 anywhere but I saw on a forum comment that the expected lift would be around 880g (in addition to the battery).
I have the following camera gear I'd like to carry:
NEX 5R (around 300g)
Tokina 11-16mm with EF->nex adapter (around 600g)
I'd really like to use a brushless gimbal as well for video shooting - any recommendations for this setup?
Will the X8 be able to lift the above, plus a brushless gimbal - or am I better off swapping the lens for the SEL16F28 that is 70g?
Thanks a bunch!
  • So what did you use as a gimbal?
  • thank you for recommendations, ordered a maytech 3axis alexmos gimbal, will report on how it works.
    Some more questions:
    How do I know that the GPS is locked? At the moment when hovering, the x8 starts drifting in one direction and I have to keep correcting it, pretty annoying. There's a toggle to switch between two flight modes on the dx7s controller, but I have no idea what they are mapped to or whether or not the GPS is locking... I am only doing manual control for now, no autopilot missions.
    Also, how do I know when the batteries are about to run out so that I need to bring the X8 back down?
    Thanks guys, very helpful!
  • MR60
    I'm using and am very happy about this NEX gimbal, that is very cheap (under 200€):
    http://kamkop.de/gimbals/standard/7/brushless-gimbal-s?c=7
    Everything included (NEX5 with 16-50 lens, gimbal, GMB5010 150 turns motors, BGC board, etc) = 900g
  • ok thanks guys!
    Looking at the gimbal next - I've been spoiled using a friends Zenmuse. For the X8 however I'm looking for something more budget - something that can balance both the NEX and a Blackmagic Pocket (about the same weight).
    Any recommendations for the gimbal? Is it worth going 3 axis vs 2 axis (more weight?) and can I power the gimbal off the same 3S as I fly with or do I need an extra battery as well? Is the 4200mah 3S that came bundled with the X8 ok or should I get beefier batteries?
    I've decided to drop the Tokina because of weight and go for SEL16F28 with the UWA addon (or similar for the blackmagic), that should leave me with:
    Camera: 300-400g
    Gimbal: RCtimer ASP 3 axis maybe? seems to be just under 700g
    Lens: 100g
    So total payload around 1.2kg
    The X8 seems to have pretty good lift, I am not too worried about the flight times (6-7 mins would be fine).
    Doable? Comments?
  • I would not use a 4S all the testing done has proven to not really be worth it. You would have to down size props etc etc. Read the recent  posting about 3 cell vs 4.   The nex should carry just fine with what you have. As far as gimbal goes it all depends on what you want to spend? There is RC Timer stuff and then you have Zemuse stuff. Kinda in the middle is the Tarot which we have had very good luck with. You will have to figure out where you can mount the gimbal and what will work to keep the other things out of the video/photo and have the CG right on the copter. The 3DR stuff kinda is a PIA with mounting a gimbal where the batteries are for balance. But you can easily diy a very nice vibration free setup. So you will have some work and testing to do.
    As far as weight savings go you might want to think about the stock lens that goes with the nex it will give you better performance.  If you find that you can't get into a decent hover around middle throttle and are going 75% you will need to lighten the load.
  • Personally, I like to keep the payload weight low, 'cause weight always costs flight tome and flight time is precious. With the Tokina, a BL gimbal and video Tx etc. you'll have a payload of around 1.5 kg which seems to be a lot, even if the 3DR X8 is able to lift that weight. Apart from that a zoom lens seems to be a bit pointless to me without the ability to use the zoom function.
    That's why I use the SEL16F28 on my copters - but it gets quite soft in the corners when wide open. I always wanted to check out the new SEL20F28...
    Good luck, Jorre
  • T3
    Not sure how they figured out the specs. But you might want to try a 4 cell battery it'll give you more power. But just like DIY drones need to experiment see what works for you.
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
