Hello,
I have 4 arducopter ESC 20A and 4 motors (850kv, A-2830/12). Power is coming from a power supply 12V 2250mA. The input (white wire) of the ESC is connected to my arduino (pin 9) and the ground (black wire) to the gnd of the arduino. I use the Servo library and send a minimal signal (700) for a few seconds and then start sending bigger values.
Sadly the motor only stutters, it never really turns. It does that for all combinations of motors and ESC I tried.The ESCs always make the correct little sounds at the beginning.
There are many things I had to solder and I am wondering if it could be a problem with the solder joint ? It was the first time I soldered anything. I watched many videos to see how to do but I have no experience at all. The circuit is as follow and everything with a * was soldered by me:
Power plug jack == jack to Deans* == Deans* to ESC to plugs* == plugs* to motor
1. Do you agree that it most certainly is a problem with the soldering ?
2. Do you need more information, or even a video, to help ?
3. How to know which solder joint is bad ?
Thank you
Barth
Hello,
I have soldered the ESC directly to the motor and it runs ! :)
I tested with the power supply and with the battery 3 cells lipo.
*However*, it does shut down if I try to run it too fast. When it happens, decreasing the speed doesn't make it restart,I have to send again a minimal signal before I can get it turn again.
Could it be another bad connection ? something else ?
Thanks a lot already for your valuable help.
Cheers
Barth
I'd try running from a 3S LiPo battery rather than a power supply.
The scenario is probably this. When your motors are starting, they will briefly draw a fairly high current (more than 2.25A) to get them going. Your power supply will go into current limit which will momentarily shut down the power causing a brownout to the ESC which will then do a restart. It will then try to start the motors again, causing a current limit ... etc.
Hi Barth,
I have built a few copters now, I had this issue on one of the very first ones i put together, there was a poor solder connection to the motor from the ESC, the motor would "chatter" away and not spin! This was some time back now, there was a recommendation to remove all the "connections" between the PDB ESC Motors, so you solder each point not use a connector, after I did this the fault was gone, motor worked fine :) I now build all copters without the connectors and solder each and every point from the PDB to the ESC to the motor, not had another motor "chatter" from that day!!
Please take the three wires from that motor and solder direct to the ESC's wires, let us know how you get on :)
Regards
Martin.
www.buildyourowndrone.co.uk
