Hello,
Today I continued to setup my T450 with PixHawk and traditional hely.
I did three flight to tune the PI Rate Roll & Pitch but at the starting the fouth and checking the servo beavior I found may be a bug.
1. If I move the rudder stick all the cyclic servos move !
2. If I try to roll right NO servo moves
3. If I try to roll left the movement is too too crisp.
I Attach to this post the log
My setup is
ArduCopter V3.2.1 (36b405fb)
PX4: ce602658 NuttX: 475b8c15
Frame: HELI
PX4v2 002F001F 33334702 31313533
My radio is a Taranis plus, about the first topic, I checked the taranis moves only the rudder the others not, effectively at the datalog looking at the data log when I move CH4 = Rudder others input still steady.
The connection between Rx (FrSky X8R) and Pixhawk is via SBUS.
3691233295?profile=original
The same CH4 maneuver then Out 1, 2 ,3 move
3691232981?profile=original
This is not so good :(
2015-08-09 18-47-51 1.bin
  • Hello, nobody read this post.
    This behavior is critical, resetting the pixhawk parameters and retuning the issue disappeared but, today if I move YAW stick still present a small pitch movement.
    Please could somebody help me to understand ? Or more infos are needed ?
    Paolo
    • This reply was deleted.
      • Mode 3 transmitter, so the right joystick manage throttle and yaw, for this reason I wrote about this behavior.
        The strangest thing is that I reset the pixhawk parameters to factory default the I retune the copter the issue re appear I'm using the last official release the 3.2.1.
        Paolo
