2 weeks ago, we've built an Easystar model, customizing the default package with various new materials (I'll update this post as soon as I've got the complete references for each part):
- brushless motor
- 6 channels RC command (for fpv-tilting later)
First flight, 5 seconds flight-path
We live in Toulouse, France, and we've got a park big enough on a hill, just east of the city center.
After few attempts to make the plane flight, we noticed easily that the plane was only going on its right, making it impossible to control anything.
Flight path was something like this: launch the plane, go 10 meters straight, it began to turn right, went upward, tilt on the right, and went down right in the grass. Time of flight: 5 sec.
Major problem: turning right
Something if not right, we've tested 2-3 things since then: remove the wings (middle and stabliators), put a string on the gravity point to keep the plane in air, start the motor and the plane naturally go right.
By putting back the stabliators, we need to move the tail in such a way that it's really bent to the right of the stabliators.
Has anyone encounter this problem?
We have doubts on the reason of this problem, any help and advice is welcome :)
update: correct 10 min to 10 meters flight path
Hello,
i live in Toulouse too, i have an EasyStar too and the same problem!
Be welcome!
But i can not explain what...
If this is your first aircraft try power off glides until it flies straight, maybe you could post a picture of the surfaces.
Welcome to DIYD, remember its always darker before the dawn, it will start to work.
