Hi everyone,
I saw that recently a new Configurator source code appeared in the arducopter svn repo. It seems to be written in C#. For me the main flaw with the original configurator was that I couldn't run it on linux (ubuntu 10.10) , and I had to reboot in windows (which I never use) every time I wanted to use the configurator. So when I saw the new code I though "maybe I could use it on linux with mono". So I installed monodevelop and I built the configurator. There was no error (only a warning), but when I launch ArducopterConfigurator, I can only see a windows for a few miliseconds, then I get this message in the terminal:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ArgumentOutOfRangeException: '0' is not a valid value for 'Value'. 'Value' should be between 'Minimum' and 'Maximum'
Parameter name: Value
at System.Windows.Forms.ProgressBar.set_Value (Int32 value) [0x00000] in :0
at (wrapper managed-to-native) System.Reflection.MonoMethod:InternalInvoke (object,object[],System.Exception&)
at System.Reflection.MonoMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00000] in :0
--- End of inner exception stack trace ---
at System.Reflection.MonoProperty.SetValue (System.Object obj, System.Object value, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] index, System.Globalization.CultureInfo culture) [0x00000] in :0
at System.Reflection.PropertyInfo.SetValue (System.Object obj, System.Object value, System.Object[] index) [0x00000] in :0
at System.ComponentModel.ReflectionPropertyDescriptor.SetValue (System.Object component, System.Object value) [0x00000] in :0
I tried to determine where the exception was coming from with the debugger, but I couldn't find it.
So here are my questions:
-Is the current code actually working on a windows environment ? ( I guess it is)
-Is this error releated to the code or to my mono environment ?
-Did someone manage to make this code work on linux ?
-Where can I find more informations about this version of the configurator ? I couldn't find any in the wiki.
Sorry if this is not the right place to talk about it, but I thought this category was the most appropriate.
Thank you for your answers.
I just tested it on OSX - didn't work. I'll look into it when I get some time.
Unhandled Exception: System.TypeInitializationException: An exception was thrown by the type initializer for System.Windows.Forms.WindowsFormsSynchronizationContext ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Windows.Forms.ThemeEngine ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Windows.Forms.ThemeWin32Classic ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.KnownColors ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.GDIPlus ---> System.DllNotFoundException: /Library/Frameworks/Mono.framework/Versions/2.8.2/lib/libgdiplus.dylib at (wrapper managed-to-native) System.Drawing.GDIPlus:GdiplusStartup (ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&) at System.Drawing.GDIPlus..cctor () [0x000cc] in /private/tmp/monobuild/build/BUILD/mono-2.8.2/mcs/class/System.Drawing/System.Drawing/gdipFunctions.cs:127 --- End of inner exception stack trace --- at System.Drawing.KnownColors..cctor () [0x0001a] in /private/tmp/monobuild/build/BUILD/mono-2.8.2/mcs/class/System.Drawing/System.Drawing/KnownColors.cs:225 --- End of inner exception stack trace --- at System.Drawing.Color.get_Black () [0x00000] in /private/tmp/monobuild/build/BUILD/mono-2.8.2/mcs/class/System.Drawing/System.Drawing/Color.cs:483 at System.Windows.Forms.ThemeWin32Classic..cctor () [0x00000] in <filename unknown>:0 --- End of inner exception stack trace --- at System.Windows.Forms.ThemeVisualStyles..ctor () [0x00000] in <filename unknown>:0 at System.Windows.Forms.ThemeEngine..cctor () [0x0002d] in /private/tmp/monobuild/build/BUILD/mono-2.8.2/mcs/class/Managed.Windows.Forms/System.Windows.Forms/ThemeEngine.cs:49 --- End of inner exception stack trace --- at System.Windows.Forms.SystemInformation.get_MenuAccessKeysUnderlined () [0x00000] in /private/tmp/monobuild/build/BUILD/mono-2.8.2/mcs/class/Managed.Windows.Forms/System.Windows.Forms/SystemInformation.cs:346 at System.Windows.Forms.Control..ctor () [0x000e3] in /private/tmp/monobuild/build/BUILD/mono-2.8.2/mcs/class/Managed.Windows.Forms/System.Windows.Forms/Control.cs:1054 at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control:.ctor () at System.Windows.Forms.WindowsFormsSynchronizationContext..cctor () [0x00000] in /private/tmp/monobuild/build/BUILD/mono-2.8.2/mcs/class/Managed.Windows.Forms/System.Windows.Forms/WindowsFormsSynchronizationContext.cs:46 --- End of inner exception stack trace --- at System.Windows.Forms.Control..ctor () [0x00014] in /private/tmp/monobuild/build/BUILD/mono-2.8.2/mcs/class/Managed.Windows.Forms/System.Windows.Forms/Control.cs:1024 at System.Windows.Forms.ScrollableControl..ctor () [0x00000] in <filename unknown>:0 at System.Windows.Forms.ContainerControl..ctor () [0x00000] in <filename unknown>:0 at System.Windows.Forms.Form..ctor () [0x00000] in <filename unknown>:0 at ArducopterConfigurator.mainForm..ctor (ArducopterConfigurator.PresentationModels.MainVm vm) [0x00000] in <filename unknown>:0 at (wrapper remoting-invoke-with-check) ArducopterConfigurator.mainForm:.ctor (ArducopterConfigurator.PresentationModels.MainVm) at ArducopterConfigurator.Program.Main () [0x0002f] in /media/peejay/programs/C#/Configurator.Net/Program.cs:31 The application was terminated by a signal: SIGHUP
