C syntax question
Just reading the code for familiarisation. Could someone explain the syntax ".f" in the following line from ArducopterMega.pde please?
G_Dt = (float)delta_ms_fast_loop / 1000.f; // used by DCM integrator
  • It forces 1000 to be of type float
    The Arducopter code is C++ not C.
    f = float qualifier
    float is a 32 bits data type with 23 bits for mantissa 8 bits for exposant and 1 bit for sign.
    By default, if you type a floating point value into C++ it’s typed as a double. Consequently, if you do something like this:
    float fValue = 4.53; // 4.53 is a double
    You’re assigning a double to a float, which loses precision, and the compiler will probably complain.
    Putting an “f” after the value means that you intend that value to be a float, not a double.
    float fValue = 4.53f; // 4.53 is a float
    It means it's a float. It's C++ syntax.
