Quick question I am ready to cal my ESC’s again. But I do not want to blow it up again. I was thinking of unsoldering SJ1 and powering the board with usb Also I would be able to see the cal with the configurator. Then power the ESC’s and receiver with the battery. When all is done re solder SJ1. Does this sound ok?
Hey Scott! If I understand your question... Like Michael said all you need to do is:
1 - power up you TX and move throttle stick all up (max)
2 - connect your ESC on RX and so power it up with a Lipo battery
3 - you will hear something like a "Teletubies" music beeps
4 - set throttle stick down (min) to save the setup
5 - you will hear another beeps tone
6 - you can power it down and it's OK
When you say "cal your ESC", are you referring to teaching the ESC the endpoints as output by APM?
Assuming the TP ESC you're using is one of the Hobbywing designs where you power up at max throttle, then go to minimum to set the endpoint calibration, have you considered getting your hands on a servo tester and going the other way?
The GWS servo tester is cheap and can be used to both generate and measure servo pulse widths. Use the tester to set a sensible range (e.g. 1000 to 2000) and then configure APM to suit...
Thanks guys, I am having problems configuring the ESC's. I did it directly connected to my RX. then connect it to the APM and all I get is cal mode cant make any changes.
#define MIN_THROTTLE 670
and
if (ch_yaw > 1800) {
motorArmed = 1;
minThrottle = 970;
Regards
TowerPro w25A Brushless Speed Controller
USB alone doesn't seem to be enough to power a couple of servos when tinkering on the bench...
