Camera Stabalization not enabled in Planner ??
Since using 2.0.23 I had to upload using Auduino because using planner doesn't enable camera stabalization.
This hasn't been a problem but I am now trying to use 2.0.25 and I have major issues.
Again when using planner the camera stuff isn't enable but now when using Auduino the motors are acting strangley.  When I try and enable throttle with right yaw a one of the motors fires up.  When I use left yaw another of the motors fires up as if I am in some sort of test mode???
So I decided to stick with using planner and do without camera stabalization and now I get magor right yaw and can only fly with full left stick to correct it.
I know that all advice would be to check for vibration but I don't think that I have any as if flew great with 2.0.23 earlier today.
I could go back to 2.0.23 but I am desperate to use Loiter and RTL which I understand has improved greatly in the latest code.
Any advise would be welcome.
Philip
  • I compiled with arduio 022 and it works.. also set ch6 on radio for tuning camera tilt...
  • Just downloaded 1.0.14 planner , erased reinstalled firmware. not stab outputs 5,6 working.... :(
  • yesss!!!
    i finish my problem.. i must change in makefile to
    BOARD    =    mega2560
    but my next problem. i need to reverse the pitch servo.
    how to do?
    @jasonshort and Chris Anderson nice jobs.. i realy love ardu
    btw i thought you must include board setting for 2560 in AMP planer.
    you know.. i have promote ardu in my aeromoding club in indonesia. you can check the forum
    http://gaero.org/forum/viewtopic.php?f=227&t=8864
    i know mybe you dont understand indonesian language.. but you can see the picture..:D
    so i hope board 2560 can program by AMP without arduiono program.. so very user friendly
    Grage Aeromodelling • View topic - Sharing System Quadcopter by Rahmatjeni
  • i have same problem to
    ch 5 & 6 is no PPM signal (i have check using osciloscope)
    but in ch 7&8 have PPM signal. but no the servo is not move / respon
    not i'using ardu  2560 board and AMP planer last vertion (uptade juni 21)
    camera stabilization is on by default and not an option in the planner. I just tested it and it's working.
    Sounds like you have other config problems. Can you retry everything from scratch?
    Jason
    Are you sure? Last time I checked, stabilization was turned on by default. just like the manual says:
    http://code.google.com/p/arducopter/wiki/AC2_Camera
    What RC outputs are you using?
    As for the other stuff, just load the latest firmware (2.0.25), erase/reset your board (you probably scrambled your EEPROM when you were working with Arduino) and do a setup from scratch. Calibrate your ESCs again. It's working fine for me.
