Can not calibrate transmitter for Pixhawk
I have Taranis transmitter. I am using the receiver that came with the Taranis witch is a Frsky X8R. I have tried to connect it to my my pixhawk using a PPM encoder I bought from 3dr and also using the "smart port". The receiver gets power and connects to my radio but I can not do the radio calibration mission planer. the bars on my computer don't change when I move the sticks. I am trying to do this on a 3dr y6 that I built form a kit. This is my first multi rotor so I may just be making a simple mistake.
      • Check if the SBus plug is correctly connected  on both sides.
        ie  - + S
      • You'll have to determine the channels on the radio to correspond to the channels on the PixHawk
        Mine are a bit different from standard because I was using a Spektrum before, and you'll have to set up the channel order accordingly to yours.
        After doing this then the channels should appear on the MP radio calibration screen
        3702671258?profile=original
        3702671177?profile=original
        3702671272?profile=original
        3702671199?profile=original
        • thanks
          Is that on companion9x?
          • update companion....
            • yeah Im going to see if i have more luck with the windows version.
              thanks
              • My screenshots are from the Mac version
                • I don't know what this issue was but the windows seems to be working.
                  thanks
                  • I'm probably just doing something wrong but when i eject my radio it says EEprom bad or something like that. And erases  everything on the radio.
                    thanks
                  • Check correct connections
                    Program the radio like shown above. If it doesn't work......
                    The Taranis is a great radio but not very easy to begin with.
                    Connections on PH and X8R
                    3702938445?profile=original
                    3702938582?profile=original
          • yes. it´s easier than taking pictures from the radio :)
