I arducopter code " define " Tab I see
/* Expansion PIN's that people can use for various things. */
// AN0 - 7 are located at edge of IMU PCB "above" pressure sensor and
// Expansion port
// AN0 - 5 are also located next to voltage dividers and sliding SW2 switch
// AN0 - 3 has 10kOhm resistor in serial, include 3.9kOhm to make it as
// voltage divider
// AN4 - 5 are direct GPIO pins from atmega1280 and they are the latest pins
// next to SW2 switch
// Look more ArduCopter Wiki for voltage dividers and other ports
#define AN0  54  // resistor, vdiv use, divider 1 closest to relay
#define AN1  55  // resistor, vdiv use, divider 2
#define AN2  56  // resistor, vdiv use, divider 3
#define AN3  57  // resistor, vdiv use, divider 4 closest to SW2
#define AN4  58  // direct GPIO pin, default as analog input, next to SW2
                 // switch
#define AN5  59  // direct GPIO pin, default as analog input, next to SW2
                 // switch
#define AN6  60  // direct GPIO pin, default as analog input, close to
                 // Pressure sensor, Expansion Ports
#define AN7  61  // direct GPIO pin, default as analog input, close to
// AN8 - 15 are located at edge of IMU PCB "above" pressure sensor and
// Expansion port
// AN8 - 15 PINs are not connected anywhere, they are located as last 8 pins
// on edge of the board above Expansion Ports
// even pins (8,10,12,14) are at edge of board, Odd pins (9,11,13,15) are on
// inner row
#define AN8  62  // NC
#define AN9  63  // NC
#define AN10  64 // NC
#define AN11  65 // NC
#define AN12  66 // NC
#define AN13  67 // NC
#define AN14  68 // NC
#define AN15  69 // NC
Can you please make me understand what are " AN " and the value beside them..?
  • IIRC, "AN" are Arduino Analog Input pin numbers, and the number beside them (ie: AN8 62), the 62 is the actual AVR pin number.  I'm a bit rusty, but something like that.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
