Can't get Arducopter to compile
I tried to follow the directions in the forum to the 'lettter', but I cannot get Arducopter (for Arduino) to compile.
I'm running Windows 10
I installed GIT and downloaded the source.  I downloaded the MHV AVR Tools, I downloaded the special version of Arduino code. I set the sketch source directory in Arduino to the location where I had GIT store the source. (C:\Arducopter).  This gave me the directory tree C:\Arducopter\ardupilot\...)
But when I open up the files, I don't get the expected  ArduRover/ArduPlane/ArduCopter choices.
Instead, I get only some 'tools'.
I see what I think are two problems:  First, there is NO Arducopter.PDE anywhere.  The only PDE file in the Arducopter\ardupilot\Arducopter directory is 'Parameters.pde'
I checked the PATH statement, and there is no path leading to the libraries.
Previously, I had downloaded a clone of the Arducopter directory (not using GIT), and I found a copy of Arducopter.pde there.  I copied that into the directory that I downloaded using GIT, and it TRIED to start compiling.  It was then that I realized that it couldn't find any libraries, so I manually added C:\Ardupilot\Arducopter\libraries to the PATH statement.
But it STILL doesn't work.  Can someone tell me what to try next?
  • I may be way off base here, but I don't think you can compile current arducopter with Arduino, only make. I made that mistake, and looked further and I was following the instructions for APM not pixhawk (which can be compiled with arduino).
    • I wasn't trying to compile the (latest) Pixhawk verssions, only the down-rev Arduino version.
      Like I mentioned above, there are at least two problems:
      1. There is no .PDE file in the downloaded GIThub version, except in the TOOLs section, where I can build various small tools (PPM to PWM converter for example).
      2. Nothing was changed in my PATH statement that allowed the Arduino compiler to find the Arducopter libraries.
      I found an old 'arducopter.pde' file somewhere, and put that in the Arducopter subdirectory, and used WINDOWS/SYSTEM/ADVANCED  to add the path to the libraries, but still got an error when I tryto compile (the message is bad HAL file...).  I assume that was because I didn't have the proper ARDUCOPTER.PDE file.
      There must be SOMEONE who has successfully compiled the ATMEL on Windows.
      • Hello,
        I dont know if it is related with your problem but i was searching for a pde file too with the arducopter repo.I used the github application and clone the Master repo. After i click on the master branch and change it to Arducopter one i wanted. Then i found my wanted pde.
  • Totally not an export on the subject, but may be related to this thread?
    https://groups.google.com/d/msg/drones-discuss/KfV6pv-w0qw/_q46xi2F...
    • Thankjs, I'll try it.
      I was getting ready to try to compile under Linux using a Raspberry pi, but prefer to use Windows.
