Can't get off the ground, flips immediately, v3.0.1
Hy there
Again a hard morning...
After a prop failure 5 days ago I have now really trouble getting the copter with v3.0.1 into air. Before the crash I flew the RC1 version of the 3.0.1 Firmware without any problems. Now I switched to 3.0.1 and didn't change any parameters (PIDs).
What I discovered so far:
  • The Motors start spinning harder at low throttle than in the older firmware.
  • If I give a little more power and then it immediately flips to the right. I tried that now 3 times and every time it did flip. I checked the motors, exchanged the ESCs, recalibrate them, checked the Props but nothing I can't figure out why it does happen...
here is a small log from today’s flip and the config file from my QAV400...
Andy
2013-07-24 08-04 7.log
config.param
  • It is good that you have made progress, well done!
    Yes, it is essential that the APM be included in the ESC calibration. When you perform the all-in-one method, you allow the APM to set baselines for each ESC. The APM will be driving each ESC as it needs to make your quad fly.
    On my most recent scratch build, posted on Instructables HERE, I used a servo tester to check ESC/motor directions before getting the APM involved. I observed the same calibration behavior from the ESC while using the servo tester; same series of beeps and responses at the signal inputs.
    Good luck
    I suggest you read the instructions in the release thread over here.
    http://diydrones.com/forum/topics/arducopter-3-0-1-released
    Watch the videos on how to set up your quad correctly for 3.0.1.
    There are PID changes you may need to make.  If you reload your 2.9.1 parameters you will probably have problems.
  • Could you post the *tlog? That is if you haven't cleared everything out yet.
    HERE is the method.
    -=Doug
  • You can confirm motor direction by using the CLI command HERE.
    I have compiled the most common results of 'flipping':
    Reasons for multirotor flipping...
    • RX --> APM input wiring incorrect (could be either and/or both ends incorrect)
    • APM --> ESC wiring incorrect
    • If 3DR PDB, incorrect ESC plugged into assigned connectors (M1 in M2, M2 in M4, etc)
    • Incorrect airframe type selected (Quad +/-, Hex +/-, Octo)
    • Motor directions incorrect for the airframe
    • Incorrect propellers on correct motors
    • TX stick movement reversed (one or more)
    ...or combinations of any and all of the above.
    -=Doug
