Can you connect kk2,1 to a brushed motor
Hi guys!
I am currently doing an underwater drone project. i am trying to connect the drone with an flight controller chip to an brushed motor to stabilize the underwater submarine is it possible to use brushed motor?
  • I guess you need to adjust the PWM values. Also consider that those ESCs usually also have reverse. I would expect at a 1.5ms PWM pulse with the motor stops. Since multirotor ESCs are usually stop at a 1ms pulse with your flight controller is sending a 1ms pulse with on the beginning, so your motor probably turns in reverse now.
  • Hi Armin!
      Am currently using an ECS(MC230CR-Futaba) right now, but the current issue right now is when i pluck it in it just spins away!
    Armin Strobel said:
    If you use an ESC for brushed motors, why not.
    https://www.aliexpress.com/item/Waterproof-320A-Brushed-ESC-Electro...
    Hi guys!I am currently doing an underwater drone project. i am trying to connect the drone with an flight controller chip to an brushed motor to stab…
  • If you use an ESC for brushed motors, why not.
  • Please do some research on how motors work and different types of motors !
  • Hi OG!
    Any particular reason to this? sorry i am new to this hobby!
  • NO!
