Hope someone can help with this problem thats driving me mad. I have been keenly following and building UAV's since v1 of the mega. Heres my current setup.
In January i bought from 3drobotics:
1 x APM 2.5+ Assembled (side entry) with 433Mhz (europe) telemetry set
1 x 3DR GPS uBlox LEA-6
1 x APM Power Module with deans connectors
Using my original Turnigy Plush 25 SC's
Using my original BL 2217/9 motors
Radio is a JR DSX11 on 2.4Ghz
Receiver is a JR RD921 9 channel rx
Heres the problem.
When i first connected the APM to MP i uploaded the 3.01 firmware. I connected successfully and performed a magnetometer calibration and accelerometer calibaration.
I moved onto radio calibration but had some problems with binding the rx to tx to i aborted it.
After this i could not connect to MP
If i pick previous firmware in MP on the Install firmware page, and select AR2.42 AP2.74 AC2.91b i can successfully upload and connect to this. But when i go back to 3.01 i cant connect.
Using 3.01 i can go into CLI and enter commands and i have tried issuing a erase command and clear the config, which completed but still cant connect with 3.01.
I have tried 3 different windows laptops - same problem
I have tried with and without radio plugged in, speed controllers plugged in, gps plugged in etc.
Ive google for answers, the forums and watched countless you tube video. I have successfully had my quad flying on most hardware, the last being APM Mega with OilPan shield but since this upgrade i cant proceed further.
Can any one please help me diagnose this problem and give me some suggestions to try so that i can move on.
Many thanks in advanced,
Tony
I'm having the same problem - has anybody helped you with this?
Update, just in case i have updated the PPM firmware as recommended in the instructions, but still wont connect using 3.01 firmware. Can anyone out there help me to solve this problem.
Update:
I have tried loading custom firmware from firmware.diydrones.com, STABLE, LATEST and one data 28th Aug, all had same results,
If i load 2.91b, after verifying the TX light on the board flashes every second
if i load 3.01, after verifying the the blue LED C flashes 6 times and 2 blinks on the TX LED then nothing.
Tony
