Trying to get tuning to work on channel six. I have connected aux 3 to ch 6. Aux three is a rotary knob. It works I tested it in tune. However it only works one way. The values go down. Any way to mix so that it would work 50/50. Half way up, half way down. Also, tried to get the tune parameters to change while connected to usb and sitting still. That does not seem to work. Any help would be appreciated. Thanks Roman
  • You may have to do the DX8 channel calibration.  It is in the setup area (hold rotary knob, turn on power).  My DX8 knob only went from about center to one side also until I calibrated the DX8. Even then it is a little iffy on one site (will not go quite to 100%)   Then after you do that you will want to re-calibrate the channels using Mission Planner.   Hope that helps.
