Choosing motors for quadcopter frame
I'm new to drone building and have begun building my first drone.
I bought this drone frame : q450 glass fiber quadcopter frame 450mm from http://hobbyking.com/hobbyking/store/__49725__Q450_V3_Glass_Fiber_Quadcopter_Frame_450mm_Integrated_PCB_Version.html
I'm considering buying 4 AX-4005-650kv Brushless Quadcopter Motor's from http://hobbyking.com/hobbyking/store/__17922__AX_4005_650kv_Brushless_Quadcopter_Motor.html
Will these motor's fit this frame ? How can I determine what motor's will fit the frame ?
Have purchased below solder (unable to find UK plug on other drone parts sites) :
3691248298?profile=original
3691248327?profile=original
These will suffice for my soldering needs ?
  • Hello, how about your project now? In my experience, As below table is a matching table for your reference.
    Quadcopter frame and lipo battery and motor and propeller size matching table
    3702367101?profile=originalTherefore, if you choose quadcopter motors for your 450mm frame, suggest that 800kv-1000kv is the best for you.
    For mini quadcopter racing, you would want a very agile quadcopter, so having a much higher thrust to weight ratio is desirable, but for an aerial photography quadcopter that we will be flying gently, you could get away with lower power to weight ratios, but in general I would say that you should plan your build at around a 2:1 power to weight ratio, as you can always use the extra remaining weight to add bigger batteries to fly for longer.
    How to choose motor for quadcopter 2016
    How to choose motor for quadcopter?This will include information on the RPM, thrust and power.Choosing brushless motor is focused more on the general…
