Clean voltage investigation
I find it hard to maintain stable vertical height whilst flying my quadcopter, sometimes it takes almost 100% throttle to prevent touchdown and even after a short time at a stable altitude the quad either rises rapidly or starts to drop. This is all with stabilise mode on, asking the APM do do alt hold or position hold is no better, but as the guides say, I should get stable working first then look at the other modes.I built the quad from parts from HobbyKing (ESCs, motors and batteries) which having read more of this forum was perhaps a mistake.The behaviour makes me think that perhaps the motors are not getting constant clean voltage, pointing to either a problem with the battery or the ESCs. I have a couple of batteries and some are better than others but none are as good as I think it should be. This makes me suspect the batteries.Flying today the quad would get itself into a spin requiring full anticlockwise lock to hold straight. This makes me suspect at least one of the ESCs.Is there a way to test an ESC to see if it is providing a clean voltage, do the flight logs include the voltage level of the 5V rail to see if the battery could be dropping voltage sporadically?If in a worst case the ESCs, batteries and motors are just not reliable for stable flight then I can justify replacing them with more branded components. If this is the case, the what are the best/recommended brands for motors, batteries and ESCs?Sorry this is a bit ramble-y, I can't think how to describe the issues I am experiencing better. I can post logs or on board video if it would help anyone help me diagnose the problem.Many thanks,Tony
  • Hey Tony,  I am running a pretty simalar setup with the same weight.  Turnigy Motors esc's etc.  I am also using 9 inch turnigy slow fly propellers as the 8's would not give me enough lift.  I have a set of 10's but I like the motor esc temps with the 9's better.
    A 2200 mAh pack will give me 5 minutes before my low voltage alarm starts squaking.  a 4000 goes almost 10.  that is regular flying.  Hovering around I get about 15 minutes on a 4000mAh pack or 7ish on the 2200
    Your pids look like mine too. I am running a .090 on the angular rate control.
    If I did not have the LVA alarm I would loosing altitude as the soft cut outs on the ESC's kicked in.
    Oh and moving threadto flying tuning Multicopters for greater exposure.
  • I have been trying to think how to describe my copters flight characteristics and realised something that might be helpful in diagnosing a problem (the problem could of course be the human element!)
    I can maintain vertical position roughly if I only use the throttle control and move between 10 and 70% once airborne. However, if I use any of the other controls, rotation or strafing the when I release them the copter shoots upwards requiring counter action on the throttle.
    This again points me towards suspect batteries to being able to deliver the power consistently. What rating and brand batteries would be recommended for a craft of this size, 1.4kg with 4x 1100kv motors with 8x4.5 props?
    Thanks again
  • Are you saying that it sometime takes 100% throttle to hover? This would indicate that your quad doesn't have enough thrust.  Could you please list out your motors, ESC, and battery info?
    While I highly recommend the 3DR power module or a dedicated BEC for powering the APM, I really don't think that is your problem.
    If you're using APM 2.5, the best thing is to get the Power Module, which will not only provide clean power but will also let you datalog the battery voltage and current.
DIY Robocars via Twitter
14 hours ago
yesterday
Saturday
Saturday
Wednesday
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
