Hello,
I have a new tricopter frame with APM 2.6 on it. When I try to perform a compass Live calibration, it starts, but get stuck with only 3 samples saved. The figure continues to spin, but it does not take any other point.
I have checked and my board provides 3.28V correctly on the I2C port.
I have tried it with two APM 2.6 boards. I have tried it with USB connection but also with 3DR radio and I get the same results. Because of that the compass initialisation always fails.
I have tried with Arducopter 3.1.5 and 3.2beta, with mission planner 1.3.10 but also an older version 1.3.9 and I get the same issue.
Any help would be appreciated.
Double check the compass connector. I had the issue a few times and every time the solution was because of the female connector of the compass. Check that the 3 small plugs are well inserted inside the connector.
I have found myself the solution. My GPS+Compass Ublox LEA-6H was not configured correctly.
See that page for details.
Ublox LEA-6H configuration
