Hi everybody, as this is my first post. I would like to say thanks to all the people who are working so hard on this project.
While testing the current firmware in an X  frame setup I have noticed an offset of the compass by exactly 45°. I also think that this is the reason why the loitering mode does not work properly and results in circular movements. I think this might be the same issue others might have with the loiter mode.
Is there a parameter I need to change or is this a bug? APM is mounted as described here http://code.google.com/p/arducopter/wiki/AC2_Frame_Assembly
and the MAG is mounted to the shield as described here:
http://code.google.com/p/arducopter/wiki/AC2_Magnetos
Any help on this is highly appreciated.
Another issue that came up is, while using the new APM Board (v1.4) the 5V power supply is connected via a diode (D1) this used to be only the case (v1.2) when using external power. This however results in a voltage of about (4.7v) at the ATMega. While everything still works fine, the analog ref. voltage will be a bit low resulting in wrong AD-conversion. I know there is the “#define INPUT_VOLTAGE 5.0” in the config file.  However, this might be a good parameter to include in the CLI setup menu. Because everything else is working great and can be configured in the CLI.
Keep up the good work,
Niklas
  • I have hexa-plus frame, firmware 2.033. Problem still exist. True north pole must be 45 deg CCW. (maybe I must try to test it in another place?)
  • Same problem (45 deg error) in Hexa_plus configuration. Version 2.029.
  • Chris,
    Does the compass code read the frames x or + config? If not that could account for this issue?
    Best
    D
    Please update to the latest code (you can use the Mission Planner to automatically check for new code and load it). There is a new magnetometer that is now being shipped by the DIY Drones store that has the axis differently than the old one. The code has now been updated (thanks to Randy Mackay!) to autodetct which mag you have and adjust the measurement accordingly.
