Configuring Failsafe and Range Testing At The Field
My 3DR quad is using FrSky radio gear with a heavily modd'ed Turnigy 9x + er9x.  From everything that I've read this should mitigate the notorious and thread-inflating flyaway issues of the stock T9x.  That said my first "close-by" flights have gone off without a hitch and I'm ready to fly higher and farther away.  In preparation:
  • I configured my TX to emit a pwm of 950 when throttle stick all the way down.
    • For er9x loaded TX's:
    • Connect the APM to Mission Planner and open open Actions Tab->Raw Sensor View ->Radio Tab.  This will show you the PWM your TX is sending.
    • Go to desired Model->Setup Menu 2/10 ->E. Limits = ON
    • Limits Menu 6/10, lower the throttle channel's (3 in my case) lower end-point. So in my case -100 became  -125 just keep decreasing it until you get something below 975 (the default failsafe level for the apm)
  • I followed FrSky's instructions on setting the failsafe on the RX
  • I confirmed the proper failsafe settings in the Mission Planner, set mode = RTL etc...
  • Then I reset my TX's throttle channel LIMIT back to it's normal setting (Limit = -100)
  • Re-calibrated TX in mission planner
  • Go back to the Mission Planner's Raw Sensor View -> Radio Tab
  • Verify that when I turn off the TX the throttle channel's PWM = 950, turn TX back on back to 990...
My question, in the field how can I test my TX/RX range? Rumor has it that if failsafe is triggered on the APM the quad may launch and "try to fly home".  Is this a moot point if I range check keeping the quad in the exact-same spot at which it was armed?
Just trying to be preemptively cautious as failsafe's and RTL's seem to cause lots of flyaways.
Cheers!
  • it will only activate rth after being armed. so do your range check while its not armed.
