  • Desktops can be made of many different materials.  The one I'm using now is wood, so I would suggest using wood screws.
    However, there are also metal, stone, and even glass desktops.  You may want to consult the literature for suggestions on the proper connectors to use for joining a plastic unit to the respective material.
    Another alternative you may want to investigate, in lieu of a connector, is some sort of adhesive.  Again, consult the literature or product instructions to determine suitability for your particular intended use.
